Terraclean, any one had it done
  • Jimmypatch
    • Mar 2013
    • 57
    Hi gang I've got my RS2 booked in for a terraclean service on weds, has any one had it done? I changed my fuel filter, air filter and oil last week so I'm prepped to see a result.
    Hopefully at the very least the car should idle a bit better and maybe give back a bit more MPG
    RS2 1994
    Mercedes G Wagon 1987 3.0D SWB
    VW T25 2.0 twin turbo Subaru legacy engine 300BHP
  • stocious
    • Jul 2012
    • 838
    It just look like a injector cleaning machine !
    Plus there gonna have to go at your fuel rail.. Banjo bolt and copper washers, no crimping returns.. So as the rail is being disturbed, why not just get injectors cleaned for 40/50 quid.. ?
    Ps my intake valves were spotless when I had manifold off my engine 150k
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
    • Jimmypatch
      • Mar 2013
      • 57
      I'm still gonna give it a go, I've got 135k on my RS so there must be a lot of carbon build up in the engine
      RS2 1994
      • stocious
        • Jul 2012
        • 838
        Go for it, just had a set of injectors cleaned for a car at home and it made a world of difference !! Poor idle and hesitation all gone and more mpg ..
        Hope it works out
        • Jimmypatch
          • Mar 2013
          • 57
          Well I've just had it done and I've driven home, there are no big wow changes to the car immediately, I would however say that there are some subtle changes :
          The car seems to idle a bit smoother.
          The car feels like it revs more freely (I do however still have a flat spot/stutter at around 1500-2000 RPM)
          The mpg on the way home (on a B road ) was 22.8 which is ok consider I was booting it at times
          I'll report back after I've driven for a week
          So at the moment I have mixed feelings towards the benefits of terraclean
          RS2 1994
          • Jimmypatch
            • Mar 2013
            • 57
            The car feels like it picks up better, and mpg has improved, I've just completed a track day in the car and on the way home I had a massive increase in power, so I'm not sure if I have a learning ECU that is responding to me thrashing the car or wether I've just cleared out something, I'm confused
            RS2 1994
              Maybe your WGFV was stuck and just started working again?
              Do you have a boost gauge in the car?
              • Jimmypatch
                • Mar 2013
                • 57
                I don't have a boost gauge, but there is a big change in the noise that the waste gate makes, it sounds like a lot more air is being dumped, I'm gonna give the terraclean a big thumbs up and recommend it to rs2 and S2 cars. My new found power is just immense and I'm loving it, it's like I've gone back in time and bought an RS2 in 1994
                RS2 1994
                • Duffelcoat
                  • Jun 2010
                  • 446
                  Hi
                  How are you getting on with the terraclean 6 months on? Anything further to report?
                  How much did it cost?
                  Audi S6
                  • Jimmypatch
                    • Mar 2013
                    • 57
                    To be honest the car still feels good, I'm not sure if it's the terraclean or not.
                    The true test would be have an emissions test first then terraclean it, then redo the emissions
                    RS2 1994
