Hello all,
I have to replace a failed fuel pump on my 1991 Coupe S2.
There is a short piece of electrical wiring - 2 wires actually - that connect the pump itself to the underside of the round fuel tank cover (that is, this electrical wiring is inside the fuel tank).
Now, the old pump had these two wires soldered directly onto it, while the new pump has another type of connection (like the one on the attached picture), where there are supposed to be small nuts to hold the wires in place.
Can this piece of wiring (to fit the new pump) be found separately? Does it have a part number?
I hope my explanation makes sense.
Thanks for your help.
