Third time is NOT the charm
I'm not that frequent at the car wash for three reasons:
3. I have the possibility to wash at home, which is convenient and no queues.
2. It saves some money to spend on more fun stuff on the car
1. The last two times the car ignition system have had a major meltdown
The symptoms are the following after the car wash; works fully normal and fine, after one pull at WOT the car goes down and almost dies. Starting it up again it barely can hold the idle (about 400 rpm), pushing the throttle at WOT again will give about 1500 rpm with A LOT of soot. The only way to get the car back home is just to go at WOT. On 6th gear it barely can manage about 60km/h.
WHAT the F**K can create this kind of short circuit to the coils, because the only remedy the last two times was to change the coilspack and ignition modules? So that is not so cheap car washes
Washing at home have not caused these problems.
Remembered now that it actually has happend a fourth time but then I just got the car towed back home when it happened and one night in the garage solved the problem... that did not work the last two times when I drove it home.
Any hints or ideas is welcome...
I'm not that frequent at the car wash for three reasons:3. I have the possibility to wash at home, which is convenient and no queues.
Washing at home have not caused these problems.Remembered now that it actually has happend a fourth time but then I just got the car towed back home when it happened and one night in the garage solved the problem... that did not work the last two times when I drove it home.
