New Turbo Advice
  • Mark Halligan
    • 2001
    Doug,
    that is the standard plate in the photo I just cut the metal pipe off and had the JIC weld nipple welded on, I don't know if you can get them anywhere already made up, I doubt it .
    But its not really hard to do, all you need is a friendly welder and a hacksaw and file .
    Mark.
    Mark - Modded
    • Pisobiker
      • 1175
      :eek2:
      Jee, guys !! I've been out two days and now I found topics like this one... !! :wacked:
      It's gonna take an hour to read 'em all.
      Well.... let's just start from this one (from the beginning...)
      see you later
      Marco
      • Doug_RS2
        • 3847
        #48
        Cheers for all the help - the deal has been done and Mihnea, as ever, been really helpful and going to supply me with a nice new turbo
        All I have to do is get it all plumbed in for Castle Combe
        Mark - I sent you message earlier regarding your fuel pump and regulator - Did you get it?
        • Habib
          • 316
          • Home: United Kingdom Current: Italy
          #49
          what turbo u gettin? how much power u aiming for?
          • Mihnea
            • 1288
            #50
            yeah, that engine will RULE, turn da boost on!!!!!
            www.MRCTuning.com
            info@MRCTuning.com
            Workshop Directions
            • Doug_RS2
              • 3847
              #51
              I'm getting one of Mihnea's K26/K27/K29 Racing Turbo's
              I'm hoping for 420bhp, non-con-rod bending torque, but we'll see what else Mihnea can get out of it
              Word of Warning - Never, NEVER go out in Marks car - it's an expensive experience He's infected me and Greg :wacked:
              • Habib
                • 316
                #52
                are u going to stick with RS2 EM
                • Doug_RS2
                  • 3847
                  #53
                  Yes - staying with the RS2 EM - I think this is the limiting factor in the power of my car now. If I was to change the EM, there would be a lot more work to get it all to fit.
                  • Pisobiker
                    • 1175
                    Does it mean this hybrid uses k29 cold side (or maybe a k27 impeller on a k29 housing) ?
                    Do anyone have a compressor map for such a setup?
                    • audiman
                      • 4827
                      Mihnea, what sort of cost is one of those bad boy turbos?? How does a k29 housing clear the RS2 EM?? My 27 is only about 3mm away from it.
                      Tom C - www.rcmr.co.uk
                      Audi UR Quattro
                      Audi 100 C3 2.0 5 cyl 115ps
                      Audi B5 RS4 645ps 911nm
                      • Mihnea
                        • 1288
                        #56
                        No compressor map for it unfortunately but it is a:
                        K26#8 hot side bolted on a
                        K27 cold side housing with a
                        K29 compressor wheel inside.
                        The bearing housing has a 360 degree thrust bearing for increased strength, and the same turbo with a K26#9 hot side bolted onto a SQ or MTM EM (the #9 housing is the one that bolts right up to those EM flanges) can easily do 560 HP!
                        The boost curve should be 1.95-2.0 Bar overboost, falling to 1.7 at 6000 and maximum 1.5 at 7000. Torque should be 540-ish and HP about 420-possibly more.
                        www.MRCTuning.com
                        info@MRCTuning.com
                        Workshop Directions
                        • audiman
                          • 4827
                          What would upgrade cost be to someone like myself. Can my old turbo be machined to accept larger wheel? Or would you consider part-ex.
                          Audi UR Quattro
                          • Mihnea
                            • 1288
                            #58
                            Tom, the housing clears the RS2 EM the same as your K27 housing, because it is the same or thereabouts! Only the compressor wheel is a K29 and the cold side housing has been machined to accept it! The K26#8 hot side apparently already gives 0.7 Bar at 3k RPM and full kick in the *** is there by 4k. Regular sale price is about 1700-2000 Euro, but I have better conditions
                            www.MRCTuning.com
                            info@MRCTuning.com
                            Workshop Directions
