Do you have an experience with this fuel pump?My oem fuel pump doesnt work so good , so i decided to buy a "powerfull" pump to my cq20v,when the next year (if everythin go well) i want to rebuild my 7A engine.So maybe a coupe months i run car with oem power and oem injectors,until the engine will be ready.
So do you have experience with this solution?And i i mount a new "performance" fuel pump,could be there a problem with oem power?
I am choosing btw Aeromotive and Bosch 044 or others.Aeromotive is cheaper and the power numbers is +- almost same.Another question is, any problems with fitting Aero in the tank?Somewhere i read about 044 fit to tank,and with a little bit work,it fits almost perfectly.
Any experience?
Any experience?
