fuel pump Aeromotive Stealth 340 vs Bosch 044 vs others
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    Do you have an experience with this fuel pump?My oem fuel pump doesnt work so good , so i decided to buy a "powerfull" pump to my cq20v,when the next year (if everythin go well) i want to rebuild my 7A engine.So maybe a coupe months i run car with oem power and oem injectors,until the engine will be ready.
    So do you have experience with this solution?And i i mount a new "performance" fuel pump,could be there a problem with oem power?
    I am choosing btw Aeromotive and Bosch 044 or others.Aeromotive is cheaper and the power numbers is +- almost same.Another question is, any problems with fitting Aero in the tank?Somewhere i read about 044 fit to tank,and with a little bit work,it fits almost perfectly.
    Any experience?
    Audi Coupe Quattro 2.3 20V
  • Lloyd
    • Apr 2006
    • 1559
    044 is old skool, noisy and not really designed for in tank use. I've got one and whilst it works great and is easy to install into an S2, newer alternatives are smaller, more efficient and much quieter.
    I've taken some advice and will post up some alternatives to the 044 later. The experts did say that the 044 is mega reliable though, just damn noisy...
    Sent from my GT-I9100 using Tapatalk 2
    RS2+ (now sold...)
    • Tom_
      • Oct 2007
      • 1301
      But, isn't a problem with fitting some other fuel pumps,than 044 in tank??OK,i will wait.
      • GazzaG60
        • 4133
        I found 044 to be silent and give crap loads of juice
        • jade
          • Jan 2005
          • 1811
          • Home: New Zealand Current: Spain
          Yep.. mines quite and works with my power level
          RS 2 580HP
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            Mine is pretty silent too
            Not possible to hear having my super exhaust
              So do you have experience with this solution?And i i mount a new "performance" fuel pump,could be there a problem with oem power? Thanks
              If all you are doing is playing with a normally aspirated 7A, the maximum you are going to get is probably around 200 hp. The stock pump will be fine. I am running a stock 8A0906091G on an RS2'd AAN making around 360 hp. Admittedly this is the upper limit for this pump but it is a long way above what you will need. I did relay the pump directly to the battery so I got about 1V more at the pump which helps. You have no need of a 044 pump that is capable of 450 hp. Waste of your money.
              G6 Fuel pump info: http://forums.quattroworld.com/s4s6/msgs/22623.phtml
              Example of relaying the fuel pump to the battery for a guide: http://forums.quattroworld.com/s4s6/msgs/24327.phtml
              • Lloyd
                • Apr 2006
                • 1559
                Yeah, that's just it. It's very subjective just how noisy an 044 pump appears to be.
                Each of our cars is different, some noisier than others. My car is not far off OEM sound wise, which is why I reckon I can hear how noisy the damn 044 pump really is. There's zero exhaust resonance and just a nice sound, which ain't too loud.
                Not bad for a full 3" de-catted system! [Milltek cat back with a Chris Tullett custom built removable silencer in place of the 100 cell race cat]
                Here's a sound recording using my phone. Engine is running throughout. First 30secs is inside, doors shut taken from drivers seat. 43 seconds in I've got out, opened the boot and placed the phone above the fuel pump on the boot carpet, 102 onwards is outside by the rear right wheel.
                You can hear the pump throughout, most noticeable from 43-102 seconds. This is with a FULL fuel tank!
                The fuel pump specialist I spoke to recommended one of these pumps to replace the 044 as they're a more modern design and much quieter in operation. They're also designed for in tank use. Specifically, the 450 one for my car due to the power level. He also pointed out the thick sound sleeve that makes them even quieter that is safe to use in tank. The only challenge is making them fit the fuel pump basket or fabbing up something similar.
                RS2+ (now sold...)
                • GazzaG60
                  • 4133
                  stokc pump on the small rs2 turbo is ok. stock pump on precision sc61 is dead at 4k. pretty I mean very lean by just under 5k at 1.2 bar
                    Tom, the OP, is running a normally aspirated 7A.
                    • stocious
                      • Jul 2012
                      • 838
                      i thin he means which pump to fit now as hes under car that can supply fuel for a 7a turbo in future..
                      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                      • Thuppu
                        • 4115
                        Veyron has two of these.
                          Nowhere did he mention "turbo", just "..so i decided to buy a "powerfull" pump to my cq20v,when the next year (if everythin go well) i want to rebuild my 7A engine.So maybe a coupe months i run car with oem power and oem injectors,until the engine will be ready."
                          No turbo mentioned.
                          • stocious
                            • Jul 2012
                            • 838
                            Originally posted by UrS4boy
                            No where did he mention "turbo", just "..so i decided to buy a "powerfull" pump to my cq20v,when the next year (if everythin go well) i want to rebuild my 7A engine.So maybe a coupe months i run car with oem power and oem injectors,until the engine will be ready."
                            No turbo mentioned.
                            "maybe" im "wrong", "ask him"
                            • Tom_
                              • Oct 2007
                              • 1301
                              Yop, u are right...
                              Sorry for misunderstood, but i want to turbocharged a my 7A engine.So i dont buy a fuel pump twice . I am asking,which fuel pump is best to use/fit to tank, and if could happened any problems,if i use (Aero pump or 044 or different) in NA spec.
