Hi all,
What do you reckon the following symptoms could be caused by? my urS4 has low/no boost, high fuel consumption (roughly 21mpg combined) and it was reporting an intermittant 00561 fault code. When the fault was cleared it got some boost back, but not all of it. I've taken the hose from the MAF off and the MAF itself looks ok, but there is some oil in the hose.
Other things that may be related, or may not are: erratic idle when cold, but stable once it's warmed up, some hesitation on gear changes. It pulls ok from low revs and doesn't cut out and it feels like it's running smoothly, just down on power.
Any guesses anyone?
Thanks
Rob
Any guesses anyone?
Thanks
Rob
