Aux water pump question
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    When it operates with the engine off, should I expect to see coolant returning to the tank from the top little return pipe?
  • AndyP
    • 6049
    If it's any help the pump works in the opposite direction to the regular waterpump. I'll check mine next time I'm out in it, I have the lower temp switch on so it comes on every time.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      I was looking at something else today and it caught my eye that while the fabs were on and I could 'feel' water going through the 2 pipes the pump is connected to, there was no return on the tank. Somehow I was under the impression that this was the case. I'm probably wrong so a confirmation would be nice.
      Thanks Andy
        After-run Auxiliary Coolant Pump and Fan Switch and Relay Info
        I guess you missed my earlier post today in the ABY vs AAN ECU thread.
        After-run Auxiliary Coolant Pump and Fan Switch and 324 Control Module Info
        Which came from this diagram by clicking on the Auxiliary After-run Coolant pump label on the right side of the diagram (all the labels are hot links to more info):
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          That's great. Thanks
          • AndyP
            • 6049
            I checked this last night and I didn't see anything returning to the header tank.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              Thanks Andy. Sets my mind at ease!
