When it operates with the engine off, should I expect to see coolant returning to the tank from the top little return pipe?
Aux water pump question
If it's any help the pump works in the opposite direction to the regular waterpump. I'll check mine next time I'm out in it, I have the lower temp switch on so it comes on every time.sigpic
1976 RD250E / 350LC cafe racer -
I was looking at something else today and it caught my eye that while the fabs were on and I could 'feel' water going through the 2 pipes the pump is connected to, there was no return on the tank. Somehow I was under the impression that this was the case. I'm probably wrong so a confirmation would be nice.
Thanks AndyComment
After-run Auxiliary Coolant Pump and Fan Switch and Relay Info
I guess you missed my earlier post today in the ABY vs AAN ECU thread.
After-run Auxiliary Coolant Pump and Fan Switch and 324 Control Module Info
quattroworld.com Forums: After-run Auxiliary Coolant Pump and Fan Switch and 324 Control Module InfoThe Audi Enthusiast website. Forums for all Audis including A4, S4, A5, S5, A6, S6, allroad, A8, S8, TT, R8, Q5, Q7, 4000, 100, 200, v6, v8, vintage, local forums
Which came from this diagram by clicking on the Auxiliary After-run Coolant pump label on the right side of the diagram (all the labels are hot links to more info):
