The oil pressure check valve that keeps oil in the head is located behind the lower of the two oil pressure switch/pressure senders, as discussed here: http://forums.quattroworld.com/s4s6/msgs/96161.phtml
*APPARENTLY*, if you install ARP main bearing cap studs and you don't realize that there is a stud length issue in that area, you can ~CRUSH~ the check valve, causing all sorts of nasty oil pressure issues. The potential for this conflict is shown in this annotated photo, showing the approximate location of the crank center line and the short distance to the oil check valve location.
