Most 5 cylinder turbo engines are very strong(audi/volvo). I know someone in the netherlands that has a chip tuned audi s2 with over 400.000 km's. During our latest meeting we had a RR test, when this car was tetsted it gave still over 280 hp!!
Getting everything sorted out for my 5++ hp project
Stuff will wear out eventually (like turbos) but generally they are bullet proof if serviced well.
I met a guy with an S6 (100 shape) which is basically the same engine as an S2. Mine had 55k on it and his had 250k. His actually sounded smoother than mine
I stipped my 3B engine after 125,000 miles. It had 1 thou of wear on the bores Many owners on the Audi forums have massive mileage on thier motors. The important factor is frequent oil changes with a good quality oil.
I bought mine with 120k on the clock. I then gave it 370bhp on the same engine, this lasted for about a year. Left in chipped or stock form they will do 180k without too much hassle.
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
yep 164k miles on mine and only now is the (first and only) clutch is starting to slip, the last 18months its had a homefry on it.
In stock form 220/230bhp is not going to stress it, they are built to handle much more than that so providing you can find evidence of a caring keeper, you can be confident it should be fine over 100K miles.
As has been said on here many times, the key is a pile of receipts rather than a service book with Audi stamps in it.
Like a lot of things, depends how it is treated, warm that oil, the first 2 mins of the engine rotating is critical especially if its a cold day, thats why on performance engines we get oil pressure and oil temp gauges.
