What is this turbo?
I guess there's no "Blue Plate" on the CHRA or Backing Plate then..?
It's a Borg Warner, but that's where my knowledge stops.. First glance I thought it was a K24-7000..Scruff4 Lag Monster Noggy.
In Progress:
Volvo K24-7400/7000 hybrids, 2.4 heads, RS4 Rods, Tial W/G's + Screamers, True Dual 2.5" straight pipes :twisted: -
its a kkk27... second and 3. digit...
look inside the INlet for the exosport.. there are may some digit too.. may .6 housingComment
This turbocharger is a K26/27/29 mixture. Shaft and wheel = k26 with trim 1. (like the old 10V Turbo)
Turbine Housing looks like a standart Audi K26. (Volute size = 6)
The bearing housing is K26 and oil/watercooled. Could you take off the compressor housing? So that you can measure the compressor wheel?Comment
Turbine housing is K26 #6, the turbine itself K26 as well.
All you need to do now is measure compressor inducer and exducer to get a rough idea of how much power it can produce.Comment
