What is this turbo?
  • caterpillar
    • 2480
    tooo small anyway....
    • prj
      • Mar 2010
      • 6308
      400-420hp turbo on pump gas, and full boost around 3800 rpm in 3rd.
      Looks like bog standard K26/K27 to me.
      • Colesy
        • Feb 2009
        • 2980
        Originally posted by twoqu
        If the smaller dimension was 45.6mm it would be a 3060. If it was 48.3mm it would be a 3064.
        Measure right at the top of the wheel and see if its nearer the former dimension.
        Have had another measure, right at the top is 45.98mm so looks like a 3060 then.
        • Colesy
          • Feb 2009
          • 2980
          Thanks, good, that's what it was sold to me as which is a good start.
          • twoqu
            • Sep 2003
            • 3103
            #20
            Measure the tip width of the the larger dimension near the plate. That might help.
            I cannot find a wheel with that dimension.
            I was told by a reputed individual that a 3064 with a #6 would do 400bhp. The favoured comp wheel appears to be the 3072 which is what I believe MTM used to get the 428bhp of the RSR in conjunction with an #8 turbine.
            Think thats what others such as Sonic/Steve H are running.
            Once you identify the wheel you should be able to get a compressor map that should answer the question to how much it will make assuming its not some odd ball truck/diesel one!
            • prj
              • Mar 2010
              • 6308
              The KX500 is a fair bit bigger, it can do 2 bar to redline easily.
              • twoqu
                • Sep 2003
                • 3103
                #22
                The C dimension is what I was after!
                3060 should be 6.3mm.
                3064 should be 7.4mm.
