Engine/turbo help questions ..
  • audinut
    • Jul 2009
    • 2195
    Ok desperately trying to get the car ready for the RR day i roadtested the car today and i have a couple of issues
    i have never had a homefried car before so the questions may sound dumb
    Every time i boost and change gear i get the loud dump valve sound , i checked the valve and it had an aftermarket bailey valve on it so i have replaced it with an original valve but it seems the same ?
    when boosting the gauge read approx 1.2 bar most of the time , a couple of times this dropped and only came up to 1 bar - what should it read on a homefry and should it be consistent
    can i reverse a homefry?
    NOT a car dealer! just an S2/RS2 enthusiast
    Homefry ABY boost curve -
    What air filter / air box or cone are you running?
    Make sure that you have the DV the correct way around (nipple should be horizontal) and that the nipple is connected to the IM at the front.
    You can indeed reverse a Homefry but you don't need to and it's a decent enough chipset for a stockish ABY.
    HTH
    • audinut
      • Jul 2009
      • 2195
      standard airbox and filter , dv is connected as you describe , from the graph i guess my 1.3 bar is normal
        Have you got an RS2 IC?
        You'll only really see 1.5 Bar if you give it WOT from 2500 rpm in 4th/5th/6th
        • Christophski
          • 3632
          I thought homefry was 1.2 bar in 1st-4th then in 5&6 it was 1.4bar.... I think but I can't be sure. The Baileys unit should be fine. I have had one on for years
          • audinut
            • Jul 2009
            • 2195
            i have only seen 1.3 max , i think its standard IC i cant tell
            • Christophski
              • 3632
              Yeh mine only does 1.3 I think mind you I don't usually get the chance to try reach that on the roads I use anymore
              • audinut
                • Jul 2009
                • 2195
                why so noisy though the constant woosh woosh woosh noise SUCKS
                • Christophski
                  • 3632
                  Mines not that loud. Maybe yours is different. Standard ones aren't atmospheric (?) and maybe the one you have is. Mines just a forged version of a standard one but made by baileys
                  • audinut
                    • Jul 2009
                    • 2195
                    na they are both non atmospheric but still lots of whoosh whoosh compared to my old non chipped s2
                      You are producing 0.5-0.7 bar more, so it will be a little louder.
                      • audinut
                        • Jul 2009
                        • 2195
                        if its normal i can deal with it
                        • Christophski
                          • 3632
                          I would say normal bud
