Just had a thought about using the voltage gauge from the aux gauges as a wideband lambda dial. Now I am aware that the stock lambda works on a 0-5V, so wanted to check the output of a wideband.
Next thing will be to look at a voltage gauge and see how it works and if it can be altered from the 8-16V range.
A few other options to consider, as the original use of the gauge is not important, just needs to be able to display 0-5V raw signal or a processed signal.
