wastegate qusestion
  • micky
    • Nov 2012
    • 147
    wastegate qusestion
    hi all i am rebuilding a aby to run hopefully about 550 bhp now my question is will a standard wastegate cope with i think its 25psi boost ? can you get stronger springs for it ect .
    or plan b i have a tial one whitch needs to be retro fitted to fit .
    Tial V60 Wastegate 60mm 44mm 38mm
    or is this one too big ?
    engine so far
    44mm be best, you can use the 60mm but you may find boost hard to control as the graduation steps let out a lot of gas at that size
    • micky
      • Nov 2012
      • 147
      is a standard one any good ?
      • diesel des
        • 3896
        Yes. Lots of big power cars run fine with stock gate.
        Sent from my GT-N7105 using Tapatalk 2
        • micky
          • Nov 2012
          • 147
          i hope so will save a lot of trouble making the other one fit .will i need a stronger spring or just wind the top screw in ?
          • diesel des
            • 3896
            What turbo are you using. Lots of people can make 2 bar boost on stock spring. But that depends on many things. A 1 bar spring might work better.
            • micky
              • Nov 2012
              • 147
              i am using a GTX3076R turbo on a wagner evo manifold
              • diesel des
                • 3896
                As that turbine is small relative to the compressor you will have loads of turbine drive pressure so the small stock wastegate will be able to bypass the required flow easier. I would fit a 1 bar spring as the turbine drive pressure will be so high that you will push open the stock spring.
                • diesel des
                  • 3896
                  Will be interesting what this turbo preforms like on your engine. 550bhp is a difficult power level on Garrett turbos. Your sorta between sizes. If you could of put up with a bit less eg an easy 525bhp then the gtx3071r would be better. For 600bhp a gtx3576r. The gtx3076 is sorta a possible problem turbo as the compressor can flow so much more than the turbine. But will be interesting. What ar housing are you using. You will need at least 0.82 but a 1.02 might help the small turbine for top end power.
                  • micky
                    • Nov 2012
                    • 147
                    i am using 0.82 hot side .won't there be bleed off using the standard wastgate ?
                    • diesel des
                      • 3896
                      What do you mean bleed off?
                        Yes but I wouldn't advise it, the wastegates are very old and many are worn seems daft to skimp on that when you've got the manifold and turbo. I run the same manifold with a turbosmart wastegate.
                        you could get a stock one refurbed but it's the same price as a new style wastegate!
                        I had major boost issues with the stock wastegate
                          power really has nothing to do with a wastegate it's control of gas flow around the turbine.
                          A wastegate does more work with a smaller turbo imo, the quicker you come on boost the more control you need to bypass the turbine to stop overboost and regualte boost levels.
                          Big turbos the wastegate does ****** all until it comes on song later in the rev range
                          • micky
                            • Nov 2012
                            • 147
                            i agree is my tial waste gate ok or too big ? i dont realy want to spend another £500 smackers on another one
                            what boost are you running and bhp you getting ?
                            • diesel des
                              • 3896
                              Just try your stock one before you get carried away. Check your stock one is serviceable and give it ago. As I say you will have high back pressures with this turbo when pushed so the realitivly small stock wastegate will cope easily. Assuming its in good order.
