diamond washer
1. Its easy to miss if you arent aware of it. Many moons ago I did a cambelt change and forgot to change it without ill effect, however I would recommend changing it.
2. Potentially as this is the part that ensures that the wood ruff key does have to take all of the torque
3. Most likely, I had to remove the 4 bolts from the pulley to pop it out
HTHLeave a comment:
It could have stuck to the pulley, I seem to remember that if it's missing the cambelt will 'walk' to the back of the cam pulley.Leave a comment:
diamond washer
Hi guys , theres a post in wanted about the diamond coated washer between the pulleys
i didnt notice it when i did my belt
1. should i have noticed it?
2. if it isnt there am i headed for catastrophe
3.may it have been stuck to the front pulley ?Tags: None
