Gtx35 on a 2.2
  • Laaf
    replied
    Originally posted by prj
    Pushes the spool 500 rpm down and so makes the GT35 turbine semi-viable.
    I personally don't fit Garrett on anything anymore though. It's like a lottery. Sometimes you get lucky and they last for a long time and give no problems, but often you don't.
    Which turbos are the choice then, as I've always imagined Garretts being reliable.
  • mushasho!
    replied
    PTE5862=GTX3576.... This is what I run...
    Sent from my HTC One using Tapatalk 2
  • PRY4SNO
    replied
    This is a good thread; it's very relevant to my current research.
    I've been leaning toward an HTA3576 or 3582 in a .82AR (granted this is for a 2.5L stroker with w/m).
    What's the consensus on Precision? What's the comparable size for a 35r? I'd wager a 5858? Or more like 6262?
  • prj
    replied
    Originally posted by DJones
    True, to be honest I'm not really interested in the numbers which is why I only recently put it on the rollers. I'm more interested in how it feels on the road and I wouldn't want it any quicker nor any more lag so all in all it ticks all the boxes for me.
    Considering the weight of your car I can very well appreciate that.
    It really depends on the chassis with these engines as well. A 1200kg car with 500 hp is much faster to drive than a 1700kg car with 600
  • Nik0las
    replied
    you can go for GTX3576r i think is the optimal variant for a street car.
  • DJones
    replied
  • prj
    replied
    Don't forget w/m injection. Dynos measure inlet temps at the air pickup, not at the manifold. A fan usually does not cool as well as having the car on the open road, so chemical intercooling always gives way higher numbers on the dyno (same experience for me, I always get higher numbers as well).
    The car is still faster on the road of course, but the numbers get a little over-exaggerated compared to non-chemically intercooled cars as a result of these peculiarities IMO.
  • DJones
    replied
    I must be a lucky one, quite happy with mine early spool and 480 from a GT3071.82 I honestly think anything bigger would spoil it.
  • prj
    replied
  • Pat D
    replied
    Much difference if it were a stroker?
  • prj
    replied
    4500 is optimistic IME, more like 4700.
    After 500hp these cars at standard displacement are just straight line drag race cars.
    Not very much practical use.
  • Rocco
    replied
    water-meth + GTX3582 + road use on a 2.2 would be nice +700Hp
  • A80Avant
    replied
    Its not a street car then.
    Its simple. If your aim is 600+ then you loose the fast responce. Your car will wake up after 4500rpm at least on every gear. Making the head better usually delays boost but gets more torque everywhere.
  • jsws3
    replied
    .82 and ill give up some rpm in full boost for 600+ hp
  • vti2
    replied
    Not bigger than .77
