Turbo studs...
  • Alex Rhys
    • Feb 2013
    • 166
    Turbo studs...
    Can they be replaced just like any other stud? As you can see, the nut just didnt want to play ball...
    Yeah but getting them out is another matter! Use the two nut on the stud to remove or a stud removal tool
    • Kieron20V
      • Mar 2008
      • 1505
      Looks like you could probably clean that up with a thread restorer or die. Save you the hassle of pulling the stud.
      Sent from my HTC One X+ using Tapatalk 2
      1994 URS4 Avant RS2+
      • europeanme
        • Oct 2005
        • 3817
        really?.... looks a little stripped to me but hey you never know...
        • Laaf
          • Oct 2010
          • 275
          You've got the WG flexi wrong way round.
          • AndyP
            • 6049
            Good spot, I bet there are loads out there like that!
            • Alex Rhys
              • Feb 2013
              • 166
              Thanks for the stud tips... ill get back on it in the morning. Thats how the wg flexi was and tbh I wouldnt have known any different - whats the problem with the wg flexi being fitted this way?
              • Laaf
                • Oct 2010
                • 275
                The other end is flared so having it that way restricts flow quite badly. And on the corrugated pipe there is a arrow stamped somewhere indicating direction of flow too.
                • my2000apb
                  • Jul 2010
                  • 637
                  weld a huge nut on there and back the stud out while its still hot, works like a charm
                  BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
                  DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
                    as detailed in one of my posts:
                    • Alex Rhys
                      • Feb 2013
                      • 166
                      Incredible...
                      I am blown away by this forum.
                        I'd always ditch that flexi for after market given than it goes from 2" to 1" and seriously restricts flow
                        • Alex Rhys
                          • Feb 2013
                          • 166
                          Ditch it for what, a straight section made up by an exhaust place or is there somewhere you can buy off the shelf?
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            Whatever it's replaced with must be flexible to allow for expansion, otherwise the heat cycles will crack the manifold and/or down pipe. Unless your going for serious power and the mods that go with it I'd just turn it round the correct way and wouldn't worry about it, sure it creates a bit of back pressure but if this was a problem the engineers designing the exhaust system wouldn't have put it there.
                            1990 B3 2.0 80 quattro.
                            1992 C4 2.8 Avant quattro
                            1994 MTM RS2.
                            1998 B5 TDI quattro Sport.
                            2000 B5 TQS.
                              Nowt wrong with the stock flexi if you are on the standard turbo, even RS2 its not a problem so I wouldn't bother. Yours does look pretty gnarled up though, so needs a bit of TLC by the looks.
