Wagner intercooler
very strange to hear that you had to cut that part .....
at this point should not be any issues for sure ...
If someon got a close picture of the RS2 crossmember i can do some magic i Paint and show you where i hav to cut it.Comment
okayyyy, now I see...
you have installed Evo Upgrade Intercooler http://www.wagner-tuning.com/thumbna...axx=500&maxy=0
on your S2, but you have changed into RS2 cross member so you didn't have to use that Stainless Steel Bracket for easy mounting to your original S2 Cross Member,
and if I understand correctly something had to be modified here (marked in red) ? :
p.s> but what for is needed that short silicone hose on another side ? ?
normally this intercooler connection goes very nicely on the top of cross member pipe, just needs proper O-ring inside intercooler pipeComment
The silicone hose is known as a MarkH mod.
As the joint between the inter cooler and the cross member relies on the rubber o ring to seal it can be the cause of lots of boost leaks.
So the use of a reduced silicone hose and 2 jubilee clips in this location virtually eliminates this...Comment
