Water leakage
  • 91_S2
    • 612
    Water leakage
    I am a little confounded. Here are the symptoms.
    1 - I am losing coolant at a rate of 1 liter every 3 or 4 days. In other words a pretty big leak. I have looked but can find no leaks in the lines or under the car.
    2 - While I was in there I just checked my oil level and I am up about 3 or 4 liters! Now that is crazy. I have never overfilled my oil to that extent.
    I am now wondering if the two fact could be related. Can I be getting coolant leaking into the block and filling the oil sump? What would the symptoms be? I am going in tomorrow and emptying a little oil from the sump to check for water there.
  • audiman
    • 4827
    Cracked head/blown headgasket by the sounds of things. Is the oil in the sump creamy coloured?? Or is it still clean??
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • 91_S2
      • 612
      Donno yet. Will be able to have a look tomorrow.
      Just when you think you see the light at the end of the tunnel ..... If it is anything, I sure hope it is the headgasket.
        Classic sound of a blown head gasket as Audiman has said.
        • 91_S2
          • 612
          Smart dudes-
          Do I have to change the gaskets for the exhaust and inlet manifolds as well? My wrench is recommending that I do that but as I see it, all I really need is the RS2 head gasket "034 103 383 AD".
          • martinjs
            • 3205
            You can leave the manifolds on and the turbo as well, and lift it all off as one rich. Weighs a ton though so get a couple of mates to help you.
            • 91_S2
              • 612
              Cheers Martin, Slobo, Tom, Jamo and all the smart and edjukated Doods!! Nothing like a litttle BTDT.
