block...
  • audinut
    • Jul 2009
    • 2195
    block...
    is this the same as aby?
    http://www.ebay.de/itm/Audi-90-100-2...item48573fc2c7
    NOT a car dealer! just an S2/RS2 enthusiast
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    nope! No oil squirters for pistons cooling! With right equipment can be done though. Ahh...and not for ABY...as it dosint have the threaded holes for the belt tensioner..
    • audinut
      • Jul 2009
      • 2195
      are aby,3b,aan blocks the same?
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        no...all 3 are different to eachother...small differences...but are not 100% the same.
          This 034100105P block comes up as a 1988-1991 Audi 100/Avant 2.0L 85 kW "RT" engine.
          Bit of a follow-up:
          The RT used 81.00 mm 034107065H pistons. It also had the same 034105021G crankshaft that the "NM" used (NM is the 2L version of the 20V 7A engine). However, the RT was a 10V, single cam, engine with a 034103351C head.
            Originally posted by Pirvu Eugen
            no...all 3 are different to each other...small differences...but are not 100% the same.
            I know that the 3B didn't have the holes/bosses for the cam belt tensioner that the AAN, ABY and ADU have but I do NOT know why the ABY and ADU blocks are different than the AAN block. They (AAN, ABY and ADU) all have oil squirters and the belt tensioner holes/bosses. What else is different on the block?
            • pasbogdan
              • Sep 2009
              • 1160
              • Country: Romania
              Not worth to mod this block.
              With that money+a little a set of 81.5 mm pistons can be bought if bores are worn.
