block...
nope! No oil squirters for pistons cooling! With right equipment can be done though. Ahh...and not for ABY...as it dosint have the threaded holes for the belt tensioner.. -
This 034100105P block comes up as a 1988-1991 Audi 100/Avant 2.0L 85 kW "RT" engine.
Bit of a follow-up:
The RT used 81.00 mm 034107065H pistons. It also had the same 034105021G crankshaft that the "NM" used (NM is the 2L version of the 20V 7A engine). However, the RT was a 10V, single cam, engine with a 034103351C head.Last edited by UrS4boy; 14 September 2013, 18:09.RS2'd 93 UrS4 5 spd sedan
I know that the 3B didn't have the holes/bosses for the cam belt tensioner that the AAN, ABY and ADU have but I do NOT know why the ABY and ADU blocks are different than the AAN block. They (AAN, ABY and ADU) all have oil squirters and the belt tensioner holes/bosses. What else is different on the block?RS2'd 93 UrS4 5 spd sedan
