Mot fail for emissions
  • chiefmechanic
    • Mar 2008
    • 198
    Took the s4 for mot today. Bought it last year and only getting it to mot now. Has been parked since 2008. Failed on emissions. CO at idle was 1.990 and HC was 3380. The engine is an AAN with an MTM chip, rs2 exhaust manifold, a stainless steel exhaust without cats and a k&n panel filter in the air box. Where do I start looking to get the numbers down.
  • prj
    • Mar 2010
    • 6308
    It's never going to lawfully pass catless.
      From memory, without a cat, you should be down around 0.75% CO. SO you're miles off! 3880 HC is pretty terrible too, you'd expect less than 500 on a car running properly.
      Pull the codes and see what's up. Sounds like it might be in warmup mode or running the wrong injectors maybe...
        Here kitty, kitty. Nice kitty.
        That and new plugs and air filter, fresh fuel and an oil change.
        Then only go for your MOT test if the car has been run hard and the coolant temps are up.
        On a related note before any of the above, you might want to check or replace your G62 ECU coolant temp sender (if bad it will cause the ECU to run the engine rich which would result in at least higher hydrocarbons (especially with no cats) and possibly higher carbon monoxide as well).
        G62 info: http://forums.quattroworld.com/s4s6/msgs/20985.phtml
        • johne
          • Apr 2007
          • 1405
          That's not going to help, he's got no cats to warm up.
          John
          • chiefmechanic
            • Mar 2008
            • 198
            Mot fail on emissions.
            CO is no problem as due to age and test limits it is allowed to run up to 3.5% vol or less. 1.990 is high though. I am also allowed 1200ppm so i need to get the numbers down from 3380. I have a 20v ur quattro with an rr engine and no cats and it runs at 0.5% vol. The HC is he problem.
            • johne
              • Apr 2007
              • 1405
              but only if it was first used before 31 July 1995? If yes, HC can be up to 1200ppm.
              John
              • chiefmechanic
                • Mar 2008
                • 198
                Mot fail
                Yes. 1st registration 1993. oil changed and air filter checked. K&n panel filter in the air box fitted
                  There's your problem. K&N filter.
                  That and no cats (don't care about your rr Urq story, that is not the car in question) and not checking that the G62 is working properly.
                    John
                    We have an old diesel VW LT van which only does a few trips to the beach every year, it will not pass emissions unless you thrash it about 5 miles down the dual carriageway and back then drive it straight into the test station while it's still hot.
                    • johne
                      • Apr 2007
                      • 1405
                      As it's pre 1995 no cat is not a problem, just got to get HC below 1200. I don't understand why the K&N should be a problem with that?
                      John
                      • johne
                        • Apr 2007
                        • 1405
                        mmm, I think diesel is the difference here.
                        John
                        • chiefmechanic
                          • Mar 2008
                          • 198
                          Emission fail
                          Any idea which spark plugs I should use. Will the standard plug work well with a lightly modified engine. I tend to drive sedately with a minor thrash now and then.
                          • caterpillar
                            • 2480
                            have 40% full with gas, then fill E85 in....ca 10 liter
                            • s2driveruk
                              • 12696
                              we dont have e85 here unfortunately - i wish we did for exactly that purpose
                              1992 3b S2 Coupe
