I have a issue with my aby engine, it first started off when I booted it from cold with out letting it warm up! what it did was smoke like a chimney when it was at idle so I thought I blew the turbo so I got a recon turbo, when I fitted the turbo I noticed the turbo which I removed did not have any traces of any oil but noticed a bit of oil in the bottom of the the hose on the cold side. once I built it all up it was still there and after doing a bit of research on the forum I put it down to the pcv valve so I disconnected this and the breather which connects from the rocker cover to the rubber hose to the turbo and I still have the same problem. I haven't lost any power also it does not burn any oil whilst driving or when im on full boost.
Any ideas?
cheers
also the previous owner had the engine rebulit by a audi techy over a year ago and everything was replaced.
Any ideas?
cheers
