Large puff of smoke and no pull from turbo
  • Monkeymagic
    • Mar 2012
    • 3419
    Well if it was between the two indents then you have put about 2 litres too much oil in.
    I cant view that link on my phone...
      Oops yes, sounds like way too much oil, might just be sucking it up the breather system and burning it.
      What I don'r understand though is that you say the oil is still on the top mark?? Are you sure you have the dipstick located properly?
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        Yes dipstick is in the correct location, I'm waiting for the engine to cool so I can get right reading, it is currently pointing towards being overfilled but I assume that is since it's still hot? (About 1 hour ago I parked it)
        1996 S2 ABY Silver
        • Monkeymagic
          • Mar 2012
          • 3419
          20 mins is enough. Drain it and pray it is being forced thrpugh the breather.
          • nip
            • Apr 2006
            • 1786
            • Home: United Kingdom Current: Abu Dhabi
            #20
            Is the car parked on lever ground, and u only have to leave it 20 mins to check the oil
              It only takes a couple of minutes to stabilise when you park up. The oil just has to run down into the sump from up in the top end. It's really important that the car is sitting on level ground when you check the level though, Malta is pretty hilly, are you parked on a slope?
              • rynaqui
                • Mar 2012
                • 2752
                • Country: Malta
                #22
                Yes it is parked on level ground, looks like it's overfilled with oil then
                1996 S2 ABY Silver
                  It's pretty obvious who the slowest typist is here!
                  • nip
                    • Apr 2006
                    • 1786
                    #24
                    Lol john, I fell for it too
                    • nip
                      • Apr 2006
                      • 1786
                      #25
                      Naughty naughty lol , just drain it then drive it
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        #26
                        I can get it up on jack stands as I've had it up before to fix a loose exhaust hanger, I've never done an oil change myself, should I be ok?
                        1996 S2 ABY Silver
                        • nip
                          • Apr 2006
                          • 1786
                          #27
                          Lol u should be fine
                          • Monkeymagic
                            • Mar 2012
                            • 3419
                            As long as sump plug comes free it very simple. Put 4.5. Litres in next time though....
                            • rynaqui
                              • Mar 2012
                              • 2752
                              • Country: Malta
                              #29
                              Thanks guys, last oil change was about a year ago this time, hoping the plug won't give me any problems..
                              1996 S2 ABY Silver
                              • Monkeymagic
                                • Mar 2012
                                • 3419
                                Drain it. Re fill it then drive gently for a bit see how she goes.
                                Isnt 10/50 a bit thick for these engines?
