engine speed sensor, AAN
  • engine speed sensor, AAN
    Ello all,
    Dropped the fault codes on my 93 s4 this pm, only one it came up with was engine speed sensor. Erased the code, took it for a run then checked it again. Same fault code. What does this sensor actually do? what symptoms would this fault create?
    Cheers in advance
    Gav
    S2 Cabriolet.........
    gav .........
    check it running,if the ign is on un running it will come up with this............tim
      cheers for that Tim, ****** not a simple answer to my running probs then, och well!
      Nice one
      Gav
