Ello all,
Dropped the fault codes on my 93 s4 this pm, only one it came up with was engine speed sensor. Erased the code, took it for a run then checked it again. Same fault code. What does this sensor actually do? what symptoms would this fault create?
Cheers in advance
Gav
Cheers in advance
Gav
