Some people have already discovered this as it generated a little discussion at the South Mimms meet. Haven't seen this posted yet, so:
The Samco hose kit, while being top value and excellent (thank you!) rubs against the back of the headlamp casing when mounted. Even in the small amount of time some of them have been in place, some wear on the Samco can be observed.
The solutions seem to be varied - break the headlamp casing, prayer (!), and putting some small diameter hosing (split open) between Samco and headlamp. E.g.
Ck.
Ck.
