S2 to RS2 upgrade-Help
  • prj
    • Mar 2010
    • 6308
    Huge amount of misinformation in this thread.
    You don't need to worry about any MAP sensors or resistors - this is what the person mapping your car has to worry about - not you!
    I have a generic map for RS2 hardware well, and all the MAP sensor, resistor etc are included in price.
    What you need:
    Exh. manifold, fuel pump, injectors, turbo, exhaust (or at least a decat if you use the stock one).
    Most likely your coils (if still original and never changed) will not handle the higher boost, so that likely needs fixing/upgrade as well.
    As for "350 hp on stock injectors" - with 3B injectors this is possible with a 5 bar FPR, but not on ABY/AAN ones, as they flow less.
    • GazzaG60
      • 4133
      agree with prj there.
      i did 321 on the rollers on stock s2 aby injectors totally maxed out. may have made a few more hp by moving the curve and boosting less but higher rpm.
      keep it simple its easy to make hp on the i5. a good tune is key as always
      • piotr
        • Jul 2012
        • 1470
        • Home: Poland Current: England
        Thank you guys.PRJ i will pm you tonight for more details if that ok with you?
        • prj
          • Mar 2010
          • 6308
          Yes, that's alright, I'm sorry if I don't reply right away - I have a lot of work so do not visit the forum daily anymore, but I will reply asap.
          • piotr
            • Jul 2012
            • 1470
            #20
            Many thanks !
