Today i just got this volunteer for a rebuilt.it's an AAN block.
I still can see the crosshatch on the cylinder walls.The problem is
the head being removed for a couple months so the moist caused some
surface rust on the rods on the crankshaft(not terrible).I'm going to use
some 4000grids sandpaper mildly penetrated on them but the cylinder walls
and the upper block surface that directly contacted the head is having
fair amount of rust on them.I'm not sure if it's going to cause some pits.
on them.What's the best way to get them done.Do you think i need oversized
pistons on this case?If i need oversized pistons I'd consider to keep this block away
and use another AAN blocks.
