Download this this and read at your leisure:
That does not rule out other mechanical issues.
One is the flywheel pin has broken.
Another is that either the camshaft pulley keyway or the crankshaft pulley keyway have sheared and the timing is floating about.
Usually the first gives an instant cut out and no restart. For the second see below.
http://www.interworldna.com/pico/audi.html
