Which Spark Plugs?
  • mike74
    • Apr 2014
    • 615
    oooh, don't know about that I'm afraid! hopefully someone 'in the know' will answer that for you
    I've got this chart saved in my PC at work and find it useful to check plugs:
    • piotr
      • Jul 2012
      • 1470
      #47
      So which plugs have you fitted in the end Alex?Im just about to order a set .
        I'm running the NGK BKR7EIX on mine Pete - they seem perfect never a hint of a problem.
        I will be moving to a cooler unit once I've had time to upgrade my turbo and up the boost
        • SteveH
          • 4460
          I run NGK BKR8EIX with 430hp @ 2.1Bar and standard compression and they have never missed a beat. I'll be using them again.
          91 Modded 3B
          14 A6 Avant Black Edition
          • piotr
            • Jul 2012
            • 1470
            #50
            Ok ,so for my RS2+ I will be going for NGK BKR7EIX.
            • RichLV
              • Mar 2015
              • 872
              • Country: Latvia
              #51
              I'm running NGK BCPR7ET right now. No issues whatsoever. But I'll probably swap to the BKR7EIX with next oil change.
              Is the BKR change interval really 40-50k as is stated on NGK site?
              • K Simmonds
                • Dec 2007
                • 7627
                I've tried a few brands and now swear by Denso PK22PR8's.
                The NGK's BKR's are also very good as are the stock Bosch ones, think the duff batch issue has been resolved and if you get them from TPS or Audi they'll be fine.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
