A6 Question for Audi mechanics
  • A6 AVANT
    • Nov 2003
    • 321
    Has anyone changed a rad in an A6 tdi, 1999, AFN, climate.?
    I assume dismantle as per timing belt (front off) but does air con rad swing out of way to enable removal of coolant rad?
    Any help greatly appreciated as I am going to be doing this on Saturday.
    Cheers,
    Chris
    A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
  • Beetie
    • Oct 2003
    • 1517
    On Saturday? I'd have gave you a hand but i'll be drunk in Blackpool!
    • A6 AVANT
      • Nov 2003
      • 321
      Hope you have a hang over!!!!
      I shall be getting sore arms undoing the bumper bolts!
      Wife's work colleagues hubby wants me to do tb on tigra!!! better than my rad and it pays but need to sort Slippermobile first!
      • audiman
        • 4827
        Yes the AC rad is on rubber hoses and should swing out the way. You will have to place bumper into 'service mode', but the AC rad should just hang in there whilst you swap the coolant rad.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • A6 AVANT
          • Nov 2003
          • 321
          Hi Tom, Thanks for the confirmation. Did a '99 Passat a few months back but that was a pd tdi and was unsure about mine.
          Have employed a small mate to get his fingers in to the 10mm bolts down the side of the bumper!!!
          Saves my big mits getting damaged!
          Chris
          • A6 AVANT
            • Nov 2003
            • 321
            Thanks again Tom,
            New rad fitted,G12 A/freeze, also changed auxillary tensioner whilst I was there as it was starting to crack up!
            P/S cooler and A/C rad swung out of the way nicely.
            Cheers,
            Chris
            • audiman
              • 4827
              Good work dude. Those tensioners are always failing. I have changed quite a few of them.
              Audi UR Quattro
              • Beetie
                • Oct 2003
                • 1517
                Originally posted by A6 AVANT
                Thanks again Tom,
                Cheers,
                Chris
                And you didnt need a hand?! Oh and no hangover on saturday!
                • A6 AVANT
                  • Nov 2003
                  • 321
                  Audiman, quite common. so are alternator pulleys coming off the alternator!
                  Beetie, Pete gave me a hand, and I fixed his Mk1 golf at same time!
