Has anyone changed a rad in an A6 tdi, 1999, AFN, climate.?
I assume dismantle as per timing belt (front off) but does air con rad swing out of way to enable removal of coolant rad?
Any help greatly appreciated as I am going to be doing this on Saturday.
Cheers,
Chris
A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
Hope you have a hang over!!!!
I shall be getting sore arms undoing the bumper bolts!
Wife's work colleagues hubby wants me to do tb on tigra!!! better than my rad and it pays but need to sort Slippermobile first!
Yes the AC rad is on rubber hoses and should swing out the way. You will have to place bumper into 'service mode', but the AC rad should just hang in there whilst you swap the coolant rad.
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Hi Tom, Thanks for the confirmation. Did a '99 Passat a few months back but that was a pd tdi and was unsure about mine.
Have employed a small mate to get his fingers in to the 10mm bolts down the side of the bumper!!!
Saves my big mits getting damaged!
Chris
Thanks again Tom,
New rad fitted,G12 A/freeze, also changed auxillary tensioner whilst I was there as it was starting to crack up!
P/S cooler and A/C rad swung out of the way nicely.
Cheers,
Chris
Thanks again Tom,
Cheers,
Chris
And you didnt need a hand?! Oh and no hangover on saturday!
