3B Crank locking tool
  • lagz33
    • Apr 2009
    • 425
    Hello All
    My leaky water pump has forced me to that time again, does anyone have a locking tool I can borrow, or better yet does anyone want to do the job for me for some xmas spending money
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    You need not locking tool for just replacing the pump (if no timing belt changing is intended).
    • lagz33
      • Apr 2009
      • 425
      I thought it would be a good idea to replace cambelt while im there... even though cambelt was done in Janurary....
      • quattrostyle
        • Oct 2006
        • 6229
        Unless you did mega miles since January I'd say leave the belt, it should be fine.
        But did you not change the waterpump at the same time then?
        • lagz33
          • Apr 2009
          • 425
          Yes I did but it has decided to start leaking for some reason :/
          • quattrostyle
            • Oct 2006
            • 6229
            That's odd. Can you see if it's leaking along the shaft in the pump or the O-ring at the back? I always use some grease on the O-ring to prevent damage while adjusting the belt by turning the pump.
            • lagz33
              • Apr 2009
              • 425
              The only thing I can see is from the front there is pink dried coolant on the pump itself which someone pointed out, other than that it tends to piss coolant down from around the PS pump area, and it has progressively got worse.... If I can get away with just replacing the water pump then I will get that done and save the other parts for next time...
              • Christophski
                • 3632
                Behind the power steering pump is a small water hose which decided to split on me a few years ago. I wonder if its the saem as yours... You almost cant see the hose unless the main rad is out of the car but that would be cheaper and easier to do than a cambelt.... Its the blue hose (Replacement was done in poly) seen in pic 4 of my thread here http://www.s2forum.com/forum/showthread.php?t=61799
                • lagz33
                  • Apr 2009
                  • 425
                  Thanks Christophski I will have to get someone to have a look for me, I wish I had a run around so that I can do this work myself without risking stranding myself for a day or two
                  Do you know the dimensions of the pipe?
                  • Christophski
                    • 3632
                    No worries. Im afraid I dont as I actually just had the last little bit left laying around from a previous car I was messing around with... Im lucky enough that I dont need my car really as I use my girlfriends car all the time so mine comes out to play or when I want to use it. It is nice to have the option... Oh and I always have a van for when she wants her car, so a second car does help. I think if you ask Brian Tonks or Alex, Error 404, they may be able to tell you as both of them have engines out at the moment so might be able to take a measurement for you..... Unless you put it into a garage who are bound to have some hose that will work. All of this assuming that this is actually the issue anyway. You can just about see it with the trim cover off of the radiator, with a torch and being in the correct position. Also, make sure the engine is running to pressurise the system so you can see where its leaking from.
                    • lagz33
                      • Apr 2009
                      • 425
                      I think I am going to look into buying a little daily banger, I have an empty 1.5 width garage asking to be used and tinkered in....
                      • Christophski
                        • 3632
                        Hahaha
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          Find a nice MK2.
                          1990 B3 2.0 80 quattro.
                          1992 C4 2.8 Avant quattro
                          1994 MTM RS2.
                          1998 B5 TDI quattro Sport.
                          2000 B5 TQS.
                          • lagz33
                            • Apr 2009
                            • 425
                            Doesn't sound a bad idea, I'm guessing they are easy as pie to work on, any particular engine I should be after?
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              You couldn't get more simple and still have wheels, in seriousness the 8 valve Digifant GTi (1988-1992) is the most reliable and is probably the best all rounder.
                              Mechanically their pretty bullet proof apart from 2nd gear syncro rings which frequently crunch. Rust is my main concern when looking at one, check the arches, sills and rear panel closely especially on the post 1990 big bumper cars as the body kit can hide all sorts of horrors. Their not rot boxes by any means, I reckon most corrosion is caused by repaired accident damage.
                              1994 MTM RS2.
                              2000 B5 TQS.
