Thanks Christophski I will have to get someone to have a look for me, I wish I had a run around so that I can do this work myself without risking stranding myself for a day or two
Do you know the dimensions of the pipe?
There are two pipes behind the steering pump that tend to leak... one from the Turbo pipe to the water manifold an the second behind the thermostat housing... especially the one from the turbo has a consistency like old dry window putty and will crumble if you only put your hands on it even if it is not leaking before. Tragically this pipe is like a timebomb.
