The problem started maybe 20 days ago when temperature get litle down(around 0c)
When the car is cold he have trouble to start,and when it start(cant start if i dont hold the throtle) he acts like 1 cylinder is not work untill i make 1800rpm on throtle,after that car works perfectly,i turn it off and turn it on w/o any problem
When temperatures are lower on night it have more problems to start,and also car started white/blue smoke
Turbo works good,boost is perfect
Oil changed 2 days ago
Did coils upgrade
Any1 know what can be?
Sopose the smoke is maybe from rubber valve?
Did coils upgrade
