vacuum pipe under Throttle body
  • andyg plym
    • Nov 2006
    • 4646
    evening all, just a quick question; the pipe that goes from the pcv system to the underside of the inlet manifold....ages ago I replaced it as it was damaged....but at that time I had no large hose so just used 8mm boost hose instead. its the pipe that is directly under the throttle body that you very rarely see on here.
    Could this potentially reduce boost output?
    You want all that stuff to be air tight.
    • andyg plym
      • Nov 2006
      • 4646
      oh its air tight alright, just hope the diametre wasnt too small?
      • ManiacuV6
        • Dec 2009
        • 458
        • Country: Romania
        If you keep the interior diameter of the intake manifold's elbow(at least ) you'll be fine .
        Audi S4 2.2T 5 spd 1992 for parts
        AUDI A4 1.9TDI daily use
        Audi 80 Quattro 2.0 16V (ACE) aka Competition
          Is that Item 22 below?
          • andyg plym
            • Nov 2006
            • 4646
            23 dave
              All it does is suck vapour from the breather system when you shut the throttle, 8mm hose is fine.
                Is your one way valve ok? If you've got it apart it would be worth checking it.
                • andyg plym
                  • Nov 2006
                  • 4646
                  I replaced it a few months back as it was leaking
                    • Rusty
                      • 18953
                      Ditch all that and connect the N80 directly to the inlet and fit a catch tank
