Audi S2 Aby Gt3071 Fuel Probleme
  • juffu
    • Mar 2010
    • 26
    • Country: France
    hello,
    i got a probleme with my car.
    When a i start it im lern in fuel Afr value 17-18
    I put the vag com on it and it write
    lamba limit exeed and my lambda value is 1.250 so i got no fuel..
    I change:
    lambda
    N75
    TPS
    Air intake sensor
    check for leak. i dont have but not sur
    Fuel pressur is 4 bar for my setup and its good
    What can make my car without fuel.
    thks have a good day
    To check for leaks, did you do a pressure test?
