Paul
I read your message to Alistair reference the ecu upgrade.I have enquired about chipping my car at a local turbo specialist,and they said the actuator spring would need replacing with a stronger one.I take it you do the work on the 3b ecu,do you recommend replacing the spring with an uprated one?
How much would it be for the work doing on my ecu?
Cheers Chris.
Cheers Chris.
