Engine randomly cuts out then starts again..?
  • prj
    • Mar 2010
    • 6308
    if you pressurize the intake and it holds everything, then you need to hook up diagnostics to it and read the fault codes. One step at a time.
    Eliminate the simple, most common things first.
    When leak testing make sure you properly pressurize the intake.
    Visually "checking" is as good as doing nothing.
    Ok, I think that's it
      Boost Leak Testing Info
      Originally posted by rynaqui
      Thanks prj, will be on my list of things to check
      You might want to read through this before the weekend:
