This morning at 8am, car stopped working seemed be no ignition pulled the dizzy and the distributor gear was broke. I replaced this on side the road with a previously known to work dizzy, however I still have no spark. Is there any likely fuses or anything will got burnt out from the minute which the engine was spinning as I tried work out why I had no power at 70mph?
Yes make sure you are at TDC and then align the dizzy. As a ghetto test you can turn the dizzy whilst cranking to adjust the hall sensor window and see if you get a spark.
