Hi Andy, in the pic where the red ring is, is the location i was trying to place the bung with the air nipple on to pressurizse the system. It wouldnt fit the samco hose though. Is this the wrong location to place it for testing or do I have an oversized pipe or is it just going all pete tong???? hahaha
I am open to suggestions of locations to place the 3 bungs lol.....
Cheers John..... In that case I wonder if the bung i was supplied is the wrong sized one as it sure as will not fit in there. It disappears down the hose! Andy P would you be able to share the diameter of the bung with nipple you supply for an ABY please so I can check and see if you did accidentally send me the wrong one?
I'm in Surrey too, boost leaks and water leaks day sounds good to me. Could we also have a prize for the most leaks. Mine also water leaks over the nsf sill. The door card gets wet at the front bottom corner.
I have a genuine vag tester a compressor and a unit. Its finding the time.
I can always help any midlands members. I have never tried it on my s2 but the kit cpmes with a selection of adaptors.
