My RS2 (ADU) in standard trim has got a slight hesitation only at light/medium load, i.e. easy at 2500-3500 rpm in 3rd gear.
It is most significant when engine is cold, but is also present when engine is at normal operating temperature approx. 90 deg C, although not as distinct.
At WOT no hesitation can be felt and a dyn-test last year showed engine capable of meeting the stated power of 315 HP and 400 Nm. The spark plugs were recently changed to NGK BKR-7EIX from the original Bosch F5DPOR ones. To eliminate the spark plugs as source of this problem the old Bosch plugs was installed again, but problem persists.
Any suggestions are welcome.......
