Nasty Noise! What is it?
  • andy10v
    • 5996
    What God did you piss off?
    Sold ABY-stock
      #32
      Originally posted by newsh
      This is the purple car I bought recently
      Is this the one that leak it's oil after you son tipped it ?
      It's hard to keep up with all the various bits of grief.
      I feel your pain.
      Your luck has gotta change soon.
      Kind regards.
        I feel your pain.
        Kind regards.
        You're finding it hard to keep up!
        No it's not my son's car, that one is the Indigo Avant, it was nearly sold at one point but now back on the driveway awaiting repair.. Got most of the bits for it now.
        • europeanme
          • Oct 2005
          • 3817
          all of them by the looks of it!....
          have fun in the 'dam John....
            Yeah, well they do say.. "If you want to give the gods a laugh, tell them your plans"
            Will do mate
            • andy10v
              • 5996
              And what did you say?
              I just banged your wife?
              Sold ABY-stock
                Crank scored 3 cyls, one shell in half, rod oval.
                  And crank already had a grind and shells in 2008 not many miles since
                  • andy10v
                    • 5996
                    That sucks.
                    What is the plan then?
                    Sold ABY-stock
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Oh dear, sounds like it wasn't nailed together properly then...
                      I don't have any spares like that here, but I guess someone round here will, good luck with it, engine out time now?
                      • Rusty
                        • 18953
                        Mate, that's proper pants. Oil starvation?
                        • DJones
                          • Jun 2005
                          • 2020
                          I have a set of standard rods your more than welcome to make use of..... Just need to find them....
                          Darren.
                          • andy10v
                            • 5996
                            I have a set of rods I just removed from my 3B if DJones cant find his.
                            Sold ABY-stock
                              Dammit John you have no luck at the moment dude, be sure to be careful if you visit the "night ladies" in the Dam
                              I also have a set of rods here for you, FOC if required
                              So you just need a crank & some bearings.
                              Sounds like the last rebuild wasn't a good one - they probably rehoned the big ends too big meaning not enough bearing crush
                              • SteveH
                                • 4460
                                Bad luck! Hopefully you will find the reason for the failure quickly and get it built back up.
                                This might help - http://catalog.mahleclevite.com/bearing/
                                91 Modded 3B
                                14 A6 Avant Black Edition
