Missing ponies
  • Maddogmark
    • 19
    Missing ponies
    I have a 1.9 tdi AHU engined a4.
    It runs well if not a little under powered. I know it should run about 90 hp but I believe it is about 65hp or less. When I squeeze the air pipe after the intercooler and have the engine reved it seams to be higher up the rev range before I feel the pipe pressure up, any suggestions of what may be letting my ponies escape? Any ideas will hopefully lead to the repairing of fences and gates so I can get the best out of what ponies I have and shall hopefully find. Thank you for your help.
  • Monkeymagic
    • Mar 2012
    • 3419
    de coke intake system
    • shaun5
      • 1610
      Yep, I bet the inlet manifold is half blocked. when I did mine it was (1Z engine). As it happens ive got a nice clean manifold for sale
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        1996 S2 ABY Silver
        • andy10v
          • 5996
          If you can check fault codes.
          Good things to check anyway;
          Coked manifold as suggested (and then blank the egr)
          Boost leaks, pressure test if possible, if not visually inspect intake system (splits/tears/perished or damaged hoses
          Check/replace small bore vacuum hoses
          Check intake clamps secured
          Sold ABY-stock
            Originally posted by rynaqui
            Hurray for Exhaust Gas Re-circulation, eh?
            • Maddogmark
              • 19
              Cheers I have a spare turbo to be check out as well may consider putting that on if it's ok and decode at same time.
              • Maddogmark
                • 19
                No fault codes to check
