I use 5w40 full synthetic silkolene pro s and no use of oil,2+bar presure on hot idle and the car is 163k
Oil grades
I took the advice given on this forum a few years back and have used 10w 50 Fuchs Titan Pro S every 5k miles since (ADU)
Sometimes needs a top up between 4-4.5k miles but uses very little, engine now on 162k (miles).
Just had an oil and filter change and literally just back from a 420 mile round trip and it's running lovely, flew back up the motorways, hardly any traffic....rare these days!Comment
Lots of views as always, I gotta say had 5-30 in for 6 months all pressures correct no noise no oil use seems to run fine on it but have changed to 5-40 now.
1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remapComment
I use 10w/50 Fuchs/Silkolene Pro S in my motor and I can't fault it. Tried the Millers 10w/50 CFS one oil change ago and the car started smoking on startup. Swapped back to Pro S again and absolutely no smoking. Strange as you would think the oil viscosity would potentially cause the issue and they should be the same...91 Modded 3B
14 A6 Avant Black EditionComment
Strange one that, not sure why or how the Millers oil would particularly cause that issue. The CFS and Pro S are both a PAO/Ester group V oil, and I've used CFS in my last two 5-pot turbo's with no problems whatsoever, quite the reverse actually.I use 10w/50 Fuchs/Silkolene Pro S in my motor and I can't fault it. Tried the Millers 10w/50 CFS one oil change ago and the car started smoking on startup. Swapped back to Pro S again and absolutely no smoking. Strange as you would think the oil viscosity would potentially cause the issue and they should be the same...Comment
