will it run ok with 750cc injectors
  • JOSH,S ABY S2
    • Jun 2010
    • 109
    hi guys
    I've had it running and everything seems ok good oil pressure and idles fine but have some tappet noise so didn't want to run it to long.
    I ran it for what felt like 5-10min it didn't get that hot could it be the running in oil I'm using, its mineral 15w40
    • K Simmonds
      • Dec 2007
      • 7627
      It can take several short starts up's and cool downs before the lifters settle down, so give it another try, you really want it to run until the fan kicks in the first time as long as there's no problems which require the engine to be shut off. 15W40 will most likely be fine for running in but I found Fuch's 10W50 fully synthetic to be an excellent oil for these engines.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • JOSH,S ABY S2
        • Jun 2010
        • 109
        had bit of a coolant leak so ive got new plastic block fitting I need to fit and then ill give it another try and get it up to temperature. hope it is ok the heads meant to have been rebuilt by John read who use to build group b engines for Dave Sutton.
        • GazzaG60
          • 4133
          use proper running in oil.
          medium load thern let the engine brake.
          you may find the big turbo makes it run a bit iffy. drags to much air. regulate throttle to stop stalls.
          as pair of tights were my filter till i got the maf off and vems on
