Results of using the wrong C4 battery
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    #31
    Originally posted by nimo781
    On a separate note, is this the most ridiculous design ever? What a place to put car batteries
    The solution is cutting the thin metal bar of the seat where it could get in contact with +.
    Anything on the + will make you get the seat out 3 times when you work there thinking:"did the blanket mooved?is it still in place?"
    • sailaz
      • Oct 2009
      • 647
      • Country: United Nations
      #32
      another solution, not on C4 but anyway
      • YELL MAN
        • Dec 2005
        • 535
        • Country: Shetland Islands
        #33
        Hmm the underside of my seat has a layer of material covering the wire of the seat so the terminals cant touch any metal. It was on it when I got it.
        1994 Indigo Blue S2 coupe
        1994 80 Avant 1.9 TDI
        2005 Yamaha Fazer 1000
        1953 AJS Model 18S
          Looks metallic = conductive, to me.
          • YELL MAN
            • Dec 2005
            • 535
            #35
            This is mine
            1953 AJS Model 18S
              Originally posted by YELL MAN
              This is mine
              Looks OE factory all right. Never seen a C4 rear seat with that though.
              • sailaz
                • Oct 2009
                • 647
                #37
                yes, top side, which is not important. bottom side can have maybe 1cm of insulation material, and I assume that the one on photo has it
